Swapped Steel Driveshaft for Aluminum today
Old Oct 1, 2011 | 05:37 PM
  #21
libertyforall1776's Avatar
Exclamation
You pulled it only to put it back on? Ya should've bought my 1 piece!
FS: '82-'02 Camaro/Firebird Steel OEM Drive Shaft - Camaro Forums - Chevy Camaro Enthusiast Forum
Those 2 piece shafts gotta go!
Originally Posted by ta2mikep75
To make myself feel better about the invisible under carriage the average passersby will notice, I pulled my 2 piece drive shaft and went to work on it with a wire wheel attached to my angle grinder. After all of the fabulous grime, grit and rust were gone, I gave it a healthy coat of primer and high gloss black paint from a can. Looks good, but the guy I did run over said nothing about the performance and shininess of the drive shaft.
Old Oct 1, 2011 | 08:50 PM
  #22
That's what I was thinking. And a lot of time was spent just to pretty up something you can't even see.
Old Oct 2, 2011 | 12:24 AM
  #23
Lightbulb
That's like saying the 2012 V6 Camaro loosing 20.5 engine lbs doesn't matter either. No way that would enhance efficiency and driving dynamics, right?
GM News - United States - News
The only benefit to changing to an aluminum one is if you run over somebody, they can say ooooooh, nice shiny driveshaft!
Your engine isn't going to feel the 4 lb. difference in spun weight, but your wallet will notice a big difference.
Old Oct 2, 2011 | 01:06 AM
  #24
Apples and oranges. Rule of thumb, plus or minus, is that for every 100 lbs. you can lose on the cars weight, you gain 1/10 of a second in the 1/4 mile.
4 lbs. saved on a driveshaft equates to .004 (4/1000) of a second. You think you're going to notice that whopping "enhancement"? No, me neither.
Old Oct 2, 2011 | 01:28 AM
  #25
Lightbulb
Reportedly Each 1 lb remove from the wheel (unsprung weight) ~ 6.5 lbs removed from the car itself or sprung wt. I believe it is similar for the driveshaft, but the real difference should relate to the % of weight and HP.
Rotating mass also has to be accelerated and decelerated, so this is the other benefit of the lost weight since you don't have to move so much of it.
Old Oct 2, 2011 | 02:24 AM
  #26
It wouldn't be similar at all for the driveshaft. Think about flywheel weight when you think about the wheels or tires. The wheels, or a flywheel for that matter, are a larger around turning mass. As an object gets smaller in diameter, even if the same weight, it requires less energy to get it spinning and slowed down. So the weight savings on a driveshaft wouldn't be nearly as beneficial as the same weight savings on a wheel would be.
Old Oct 2, 2011 | 10:45 AM
  #27
Senshi09's Avatar
Originally Posted by 3800camaro
I'm in the same boat as you. But once I'm done school in 4 weeks I'll get my raise and be back to work. Oh I can't wait. Nothing like wanting to do upgrades but only having an income of $1600 a month and over $2000 in bills to pay. Gotta love life.
this is very true. Life is a peach at these times. But...
When life hands you lemons.. pee in a cup and sell it as lemonade
Because the aluminum shaft is actually stronger than a steel one. You simply bought into the hype that it's going to make a noticeable improvement in your car's performance. If you went from a heavy two-piece shaft, then yes you might notice something. But the one-piece to one-piece weight difference is slight.
When did aluminum become stronger then steel? Lighter I can understand yeah, but stronger? Thats a head scratcher to me.. explain please.
Old Oct 2, 2011 | 02:18 PM
  #28
Lighter weight doesn't always mean weaker. The steel driveshaft is about 2.5" in diameter, the aluminum one is 3". Steel driveshafts can twist like a pretzel if subjected to too much horsepower/torque. Aluminum ones, not as easily. Keep in mind, we're talking about a tube here, not a flat sheet.
Old Oct 10, 2011 | 07:17 PM
  #29
emptysmile005's Avatar
where do u get a one piece shaft steel or aluminum
Old Oct 11, 2011 | 11:37 AM
  #30
ta2mikep75's Avatar
Driveshaft Specialist Inc
Check out that site to order your drive shaft. They do steel/alum products to your specs.
Avg price including shipping is between $250 to $450 depending on your specs.
