stupid firewall.
Old Mar 5, 2005 | 02:16 PM
kdurlin's Avatar
Default stupid firewall.
how in gods name are we supposed to run 6g power wire from the battery through the firewall... am i going to have to drill a hole .
Old Mar 5, 2005 | 11:13 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: stupid firewall.
yup drilla hole and run the wire down under the dash and then behind the plastic on the drivers side and under the doorsills. its for an amp right?
Old Mar 7, 2005 | 11:55 PM
JenkinsAudio's Avatar
My 96 has a little rubber insert where wires run into the firewall on the passenger side. It's hard to get to , but u can get to it without drilling or removing any parts.
Old Apr 28, 2005 | 11:56 PM
YoungGun_Mechanic's Avatar
Yes your car should have factory holes, BUT you shouldn't be able to fit a 6g wire through it. you will have to drill a hole, and then run through. Just make sure you use a grommet on that hole so it doesn't cut through and ground itself. Personally I would run a 0g wire down along the frame of the car, and let it come up through the trunk so I don't have the nasty wires, and have a clean look. But thats just me. Have fun!
Old Jun 2, 2005 | 07:13 PM
camdriver98's Avatar
I have a 98 camaro and there was a hole on the passanger side with a rubber plug. It is plenty big enough to run a 6g wire through it. I ran a 6g wire through it and all my wires for my underbody light kit. The hole should be around where the glove box is. It is difficult to get to, but it is better than dirlling a hole. Good luck!!
Old Sep 3, 2005 | 08:26 AM
Camaro02Car's Avatar
I am guessing you have already done this but I am trying to hook up my amp and instead of going to the battery I am taking 12v constant on from behind the cigerette lighter under the center console. Then i am getting switched power from behind the center air conditioning because I dont have thoes extra buttons and found a switched power source.
77nomad
Jul 8, 2011 07:55 AM
C4r1b0u
Feb 5, 2011 08:29 PM
greenarrow
May 9, 2009 12:44 PM
Famous68
Oct 8, 2008 12:12 AM
SpecterGT260
Jun 28, 2007 09:10 PM
