Stock Fuel Pump Model Numbers?
I am looking to replace just the pump and Im having trouble finding the model numbers. I have found some reference to the AC Delco EP378 but I want to check before I order it. Does anyone have a link to some replacement pumps that fit a 95 v6 3.4 or even just the numbers would help. Thanks in advance.
rock auto http://www.rockauto.com/ i think you can still get a discount from a promotion on the site. ill have to look and see if i can find it.
So does your stock one. I am not sure your going to find the original OEM pump alone. GM conciders the pump and sending unit a single part number. When the dealer replaces it they do it as a unit.
I was looking at this unit. It would replace the one in the yellow sending unit. It just pops open and allows access to the old one to replace.
NEW FUEL PUMP WITH INSTALLATION KIT E3265 EP378 EP381 DIRECT REPLACEMENT | eBay
heres a carter for 60 bucks. not as good as oem. FUEL PUMP W STRAINER CHEVY CAMARO 95-93 V6 3.4 P74130 | eBay
Did you do the hatch method? I have had 3 Air techs in my 96 in 3 months. I would never put a Air tech in anything that it was not easy to swap. I have granatelli sitting on my work bench ready to go in once the Air tech fails again. As it stands now the check valve is not working right. If I park up hill It takes several seconds before I build fuel pressure.
