Starting problems
Old 03-21-2008, 04:10 PM
joeblow3's Avatar
Default RE: Starting problems
Is there a return line to the gas tank?? I misspoke on second post, it is the on position not the ACC
Old 03-21-2008, 04:49 PM
02StanGT's Avatar
Yes. Which engine are we talking about anyways?
Old 03-21-2008, 06:33 PM
joeblow3's Avatar
3.8
Old 03-21-2008, 07:46 PM
typeomang's Avatar
I have the same problem with my 96 3.8
Old 03-21-2008, 07:48 PM
typeomang's Avatar
i have the P1441 code.
Old 03-21-2008, 11:32 PM
aleksandr's Avatar
Same thing here. I actually went to this board to make a post about this and saw this thread. I have a '98 3800 and after sitting for a couple of hours it has a hard time starting up. I usually have to push the gas pedal about half-way to get it to start and after that there's a strong smell of gas all around the car. Yet if I try to start it a few minutes after shutting it off it starts perfectly.
Now the engine runs very well it just gets annoying and a bit embarrassing to listen to the starter struggle for 10 seconds everytime I try to start it. [&:]
Old 03-22-2008, 07:02 AM
joeblow3's Avatar
mine is a little different it won't start and the fuel pump just stays on. then later it works fine and starts up right away
Old 03-22-2008, 10:36 PM
aleksandr's Avatar
Alright well today I tried priming the pump several times by turning the key to On for two seconds then back three times. It made no difference. It still took a long time to start and after it started it ran very rough so I had to push the gas to keep it from dying.
I am suspecting that somehow my engine gets flooded with gasoline while it is off. Is that possible? Could it be that my injectors are slowly leaking out fuel into the enginewhen the car is off?
Old 03-24-2008, 08:37 AM
Ghost32's Avatar
yeah mine is still doing to exact same thing. I was told it could be the crankposition sensor. I'm not throwing any codes but I hate the fact that I have to go through that everytime I have to start her up. I'm thinking about changing that sensor for the hell of it and see what happens.
  #20
Old 03-24-2008, 08:14 PM
libertyforall1776's Avatar
Bad fuel pump possibly -- have you had a fuel pressure test?
EasternStryker
02-28-2010 09:57 AM
videojunkie1986
06-03-2009 06:02 PM
justingarcia947
10-08-2008 12:25 AM
KrazyHobo
11-20-2007 07:48 PM
jdubs1813
11-08-2007 01:42 PM
Quick Reply: Starting problems
