Squealing Belts?
Old Jul 4, 2009 | 08:27 AM
stillettoDSM's Avatar
I'm thinking I should just Replace the Alternator, my Girlfriend's most likely going to use this as a Daily Driver, so I probably shouldn't cheap out, and just Replace things since it's so Old/has so many Miles on it. I'm low on Cash right now, but I'll let everyone know how things go when I finally take it apart.
Thanks a lot for the Responses, and Happy 4th of July to everyone!
Old Jul 4, 2009 | 08:30 AM
Stix80's Avatar
happy 4th to you too i know its hard not to cheap out with times being hard but if you have new it becomes more dependable for a longer time
Old Jul 4, 2009 | 10:02 AM
If you're buying a more expensive "new" alternator, that's one thing. But some that you buy at parts stores are rebuilt and stated as such. You do realize that a "rebuilt" alternator isn't all new parts inside, don't you? A rebuilt replaces the bearings, brushes, and voltage regulator for the most part. The rest is "reconditioned".
Old Jul 4, 2009 | 07:23 PM
eBay is my friend, most of the time..
I've found a Seller that has OEM Alternators for like $45 Shipped, and come with a 30 Day Warranty, which I might just give a try.
Old Jul 7, 2009 | 06:51 PM
Quick question.. does anyone know how much the Auto Trans can hold?
Old Jul 7, 2009 | 08:38 PM
3.4 trans holds 10 pints or 4.7 liters for the drain and refill and 16.7 pts or 7.9 liters for the overhaul refill.
Old Jul 7, 2009 | 11:35 PM
You asking fluid or torque?
Old Jul 8, 2009 | 07:10 AM
My mistake, Torque, before it starts to Slip.
Old Jul 8, 2009 | 12:49 PM
I'm not sure what you're asking.
The transmission can certainly withstand anything your V6 can give it. Right up to the point of where it tires out and dies of natural causes (excessive wear).
Old Jul 8, 2009 | 11:24 PM
  #20
I figured that much, but if I were to attempt to Boost it, which is something we're looking into, really wouldn't be so hard, how much power, to the wheels, would the transmission be able to hold before it started to slip?
Probably wouldn't be any time soon, but just curious.
