squeaking
squeaking
i changed my valve covers and now it revs at 3000 then goes down to 1500 once in drive. so i drove it around the block, when i pushed the gas it began to squeak or squeal...it also smokes quite a bit. I have no idea...im not a mechanic and i dont have the money for one.
RE: squeaking
it was the gaskets. the smoke is white. Im not quite sure where its from...probably the gaskets. it comes through the intake manifold but not so much out the sides by the covers. when i put the car into drive now it seems to slam into gear. it kicks harder into reverse
RE: squeaking
Is it safe to assume that you didn't have this problem before messing withthe valve covers?
Since the process also involves removing the upper intake manifold, I'm going to say that's where to start looking foryour problem. Did you replace the intake gasket with a new one? And scrape & clean the mating surfaces thoroughly as well? If not, then that's the problem. Sure sounds to me like you have anintake manifold leak.
RE: squeaking
ORIGINAL: 02StanGT
Wait... You have to replace the gaskets?
You learn something new every day. eh?
