Speed wpers
Old 03-06-2011 | 04:22 PM
bts2014's Avatar
Default Speed wpers
So the windshield wipers on my 2001 camaro need to be tighten. I can to this decision on two bases o e when they are placed o. High speed that make a louder than normal sounds at the point where they change direction. Two the arms where they attach to the motor feels loose, but I have been unable to find an article that will show me how to tighten them if they can be. Any thoughts ?
Old 03-06-2011 | 06:40 PM
3800camaro's Avatar
You need to lift up the cap that cover the bolts. It's a black cap that stays flat when you lift you wipers up but instead you lift the cap up towards the wipers.
Old 03-06-2011 | 08:51 PM
bts2014's Avatar
Hey is there a torque requirement or just make sure they are nice and snug
Old 03-06-2011 | 09:19 PM
Massey's Avatar
Snug has always worked for me. Also it could be the bushings in the linkage or the linkage itself that is loose. You need to remove the arms then the black plastic cowl shields to see the inside linkage parts.
Massey
DiElSleL
03-08-2012 01:23 PM
DiElSleL
03-06-2012 10:54 PM
rext
67-69 V8 Tech
09-23-2011 11:49 AM
Quick Reply: Speed wpers
