spark plug firing order
any kno were i can find a chart for the firing order for a 96 3.8L v6 camaro rs? i am going to replace them and i dont think they are on there right. so i dont want to put the new ones on wrong
RE: spark plug firing order
Don't worry about the firing order, the coils are labeled with the plug number, and as long as they weren't moved around everything should be OK But just in case, 1-6-5-4-3-2 Coil pack picture is rotated 180 deg. |
what about the numberations on the coils... i got a little print out from auto zone and it said the coils should go like this
2 4 6 1 2 5 but it doesnt... on my car the coil numbers read diff.. does that matter??? and i had a new engine put in there... not new but one with less miles so it was moved around. and i dont know if they put them back on right |
Check my previous post, uploaded some pictures to help you. The front-most cylinder on driver's side is #1, odd cylinders on driver side, even number on passenger side. By the way, your layout has two #2 cylinders, and no #3 cylinder. Creates a nasty engine shake, lol
Do any of you happen to have the coil pack diagram on hand? I am also going through the process and would like it as well! Any help is greatly appreciated
