The small things that count
Old 04-04-2007 | 02:49 AM
Kardon507's Avatar
Default The small things that count
MY LEFT TURNING SIGNAL DOESNT BLINK JUST STAYS SOLID....I CHANGED THE BULB.....WHAT ELSE IS THERE TO DO?
Old 04-04-2007 | 03:04 AM
badinfluenceRS's Avatar
Default RE: The small things that count
Check the Fuse
Old 04-04-2007 | 03:14 AM
74454bb's Avatar
May 2007 ROTM
have you checked your blinker fluid level? .............................check your relay.
Old 04-04-2007 | 03:34 AM
JaySan's Avatar
did u change the front as well as the rear blinkers ?
Old 04-04-2007 | 02:50 PM
slowZ's Avatar
that happened to my blinker when one of the running lights were out. are bothyour running lights working?
Old 04-05-2007 | 02:52 AM
Kardon507's Avatar
what do u mean by running lights?????sorry i feel dumb now lol...i didnt change the first one because it was fine the problem was the back one...what happend was it was one of those hit fixes where you just hit it and then it works fine then i broke the taillight....bought nice aftermarket ones then i changed the bulb(not sure if it is the right size) and it turned on but stayed solid....where is the blinker fluid????and wheres the relay????dam i feel retarded now...but thats what the forum is for....thanks guys
Old 04-05-2007 | 03:38 AM
libertyforall1776's Avatar
Ok, the blinker fluid is not a concern, but you have to check you blinker charge reservoir -- if it is not maintaining a full charge, you may not get the blinks you need.
You DID check your blinker charge reservoir, didn't you!?! ;-)
ORIGINAL: Kardon507
Old 04-05-2007 | 11:22 PM
v6camaro00's Avatar
haha i told my wife the same thing and muffler bearing, lol
Old 04-05-2007 | 11:55 PM
usarmyrangrs's Avatar
TSCM has failed, obviously. You may need to send your car back to Chevrolet to have them reboot your Turn Signal Control Module, as it is a intricuite piece of computer circuitry.
Har. Check all the bulbs themselves, and then get into relays.
Old 04-05-2007 | 11:59 PM
slowZ's Avatar
...by running lightsi mean the orange lights underneath the headlights that always stay on. i had one out and it was keeping the blinker solid like you described, i changed it and everything worked again.
