slight overheat problem
RE: slight overheat problem
Stephen, you should add a third gage so that they can take a vote and make a decision. JK
Seriously, the fans are programmed to come on at around 220, so if the car is not traveling at a decent speed and forcing air through the radiator, the temp will rise until the fans come on, regardless that the stat is fully open at 180.
Thanks for the help. i was about to tear the fan relays out and test themand replace the temp sensor. and no greg wi don't thing i bled the system i will do it tommorow thanks.
