siphon fuel
Hi folks,
I did a search, but it came up empty. I'm working on a friends 2002 Camaro v6. The fuel pump is dead. My problem is that the fuel tank is full and I can't get any size hose down the filler neck to siphon out the fuel. I seem to be hitting a check ball or something. What is the easiest way to empty the tank? Thanks, Rob |
RE: siphon fuel
drill a hole but you will need a new tank lol.
RE: siphon fuel
Fuel Tank Draining
TOOLS REQUIRED[*]J 42960-1 Fuel Tank Drain Hose[*]J 42960-2 Fuel Flapper Door Holder [ul][/ul]CAUTION: Never drain or store fuel in an open container. Always use an approved fuel storage container in order to reduce the chance of fire or explosion. NOTE: Do not run the fuel pump unless the fuel pump is submerged in fuel in order to prevent damage to the fuel pump.[*]Remove the fuel filler cap.[*]Install the J 42960-2 into the fuel fill pipe in order to hold the door open.[*]Insert the J 42960-1 into the fuel tank until the hose reaches the bottom of the fuel tank.[*]Use an air operated pump device in order to drain as much fuel through the fuel fill pipe as possible. [ol][/ol] [IMG]local://upfiles/1197/3E3E5DDED51E4008AEB52DB81CF857E2.gif[/IMG] |
RE: siphon fuel
Reminds me of the days of stealing gas...............lol Oh what that was like
| All times are GMT -5. The time now is 09:04 AM. |
