should i get a whisper lid?
Old 03-12-2009 | 05:48 PM
rokinv6's Avatar
Default should i get a whisper lid?
i have a 2000 3.8 and i am going to add a SLP cold air intake. i was planning on getting 5-10 hp. I wanted to add a whisper lid also. Will the whisper lid add any more hp? If so, how much hp will it add and will the whisper lid work with a SLP cold air intake?
Old 03-12-2009 | 07:10 PM
02CamaroV6's Avatar
Yes the Whisper lid will work with the SLP cold air intake. You will probably gain maybe 2-5 horsepower from it. If you have $140 to spend on it then i would buy it.
Btw you should look at the 3.8 stickys before you just post a question your not sure about.
Old 03-12-2009 | 10:02 PM
bluovlh8er's Avatar
i always liked the ones that say 3800, other then that its worthless
Old 03-15-2009 | 02:29 AM
chernabog's Avatar
To be honest, take the lid off you have now, and inside you'll see the inlets inside. Take a pair of pliars, and at the base, slowly bend it back and forth, and it will snap off. Take all of them out, and use a sander to get the rough parts out. Did it with mine and made a big difference before I went nuts on intake systems.
Old 03-15-2009 | 04:58 AM
cbr600rx7's Avatar
The whisper lid is great deal for the money and just about any one can install them. I ran one on my old DD 3800 and you will notice a small difference. I was kind of shocked to be truth full. All i changed was the lid and added a K&N filter and you could fill a good increase in response not bad at all for the money. I had to but the CF one not a fan of it but at the time the normal one was back ordered. I would get the lid and see how you like it and then consider the intake kit. Just my 2 cents but yes they will work just fine together.
Old 03-15-2009 | 05:44 AM
DMateo's Avatar
Does the SLP cold air intake itself make a noticeable difference? If I were going to buy one or the other right now, the air lid or CAI, which would give more power? Or I might just buy the CAI and remove the baffles from the stock air lid.
Old 03-16-2009 | 03:00 AM
chernabog's Avatar
Here's something else we did I forgot about. After you remove the baffles on the inside, measure down to where the bottom of the filter sits in the box. From the front, drill 3/8" holes in the frame of the box, then cut them out to open up the air flow. It was another little thing we did on mine that helped. and a k&n filter helped.
Old 03-18-2009 | 01:33 PM
libertyforall1776's Avatar
Wow, nobody uses the search - this issue keeps coming back!
Get the Whisper lid, SLP CAI, and SLP's re-usable filter is better than K&Ns... It's all worth doing, and not very hard, the CAI is just a little time consuming.
luciora
02-08-2012 08:05 PM
libertyforall1776
08-17-2010 05:11 PM
Quick Reply: should i get a whisper lid?
