serpentine belt smoking- help
I was driving the other day--- I see smoke coming from my hood... I immediately pull over. Pop the hood. My serpentine belt is hanging off.
I get it towed to my house--- I buy a new belt...
And just now I put it on--- was real easy, took me 2 minutes... I doublechecked everything.
I start it and everything seems to be working great... but then after 30 seconds, it starts smoking... I look at it and the rubber is melted to the tensioner...
I have no idea, why it did this to the old belt and now to the brand new one, too?
What does this mean? Is it a bad tensioner... and/or is one of my pulleys damaged?
Help... I'm stranded here with no car...
I purchased (2) new tensioners and another new belt...
I manually tried turning the pulleys by hand... they turn relatively easily...
So, I took off the old (2) tensioners and put new ones on. And I put the new belt on now, too...
I ran the engine for a few seconds the first time, the belt slid off the top tensioner a little bit... so, I killed the engine... and put the belt back on again and double-checked everything was aligned...
I just ran it for 10 seconds... it seems to be making some sort of weird noise (which I can't pinpoint the location.) Anyways, before I put the new tensioners on, I blew a new belt... So, I want to be real careful this time so I don't blow another brand new belt ($25)
Any advice/ideas/tricks/tips or warning signs?
Thanks...
(I just want to be sure before I run it for longer than 10 seconds, that it's not going to melt the belt again or anything else...) For all I know, with the new tensioners I just put on plus the new belt, everything will be fine... but something just doesn't seem right?
Thanks...
Make sure the belt looks aligned on all the pulleys -- if a pulley was not put back on all the way, a pulley could be maligned causing issues. Sometimes the alternator bearing can go out if there was a bad tensioner for some time...
that would be the only thing i could think, is that a pulley is not functioning correctly and the belt is moving faster than the pulley. I did the same thing with a 97 firebird that i used to have. is the tensioner really tight? maybe its not keeping as tight as it should.
