Series III Swap- PCM?
I'm currently swapping out my old Series II motor for a Series III and was wondering if I needed to change my pcm out with a newer one because it is a different motor with slightly larger heads. Any advice would be wonderful. Thanks.
nope. could get yours tuned and pick up even more hp
Originally Posted by craby
(Post 694866)
Thanks so much. I bought the motor with no PCM, so I was getting a little skeptical. Anyone know a place where I can get all the gaskets and seals I will need when I swap all the accessories and stuff Im gonna need or atleast a list of parts I will need?
did you see this https://camaroforums.com/forum/93-02...nt-info-57568/
(Post 694899)
your going to need to replace the intake, both upper and lower gaskets. oil pan gasket, valve cover gaskets, exhaust gaskets. basically a head job gasket set with oil pan gasket. would be a good idea to replace head gaskets to just so you dont have to worry about it. head gasket is known to fail if antifreeze is not maintained regularly
Originally Posted by Xios
(Post 694902)
I did, but it never showed any details about what gaskets or seals I needed to buy.
Originally Posted by datafan
(Post 694915)
I am in the middle of the same exact project you are. My new motor is out of a 2006 Buick LaCerne. I bought oil pan set, upper and lower intake set, exhaust manifold, valve cover and oil filter housing gaskets at O'Reilly Auto, they are Felpro. The lower intake gaskets are the aluminum ones, and most all the gaskets have the raised rubber seals imbedded in them (whatever you call that). The sets all have the extra smaller gaskets and orings and such as needed. I also bought the aluminum elbows to replace those plastic ones on the idler pulley housing.
(Post 696408)
Thats awesome, mine came out of a 05 grand prix. Only 42k miles. How far along on yours are you? My motor is put together completely, just waiting on the clutch so we can put it back on the k member and back into the car. I used fel pro gaskets as well.
Here's pics of the project, sorry they are in random order I plan to put an article together and fix up the website. My daughter helped me pull the old motor, that's her green camaro in the background :-) 200 Camaro Engine Swap |
