Relay question ( Just for verification )
hey guys,
I have a 94 camaro that got a little banged up by a girl so its in the shop.
I just bought another 94 Camaro as a Slider lol to get me around while I order panels and stuff to fix it. this camaro came with an R title. Runs great but fog lights weren't working and i started to check it out. switch and bulbs are good. But here is my real question i need verification on.
Under my hood I opened up the fuse box and I have only 3 relays?
HAS:
Air pump, coolant fan 1 or primary, ABS, A/c.
Now its missing:
Coolant fan 2, asr/tcs, Fog lights relay, coolant fan 3
it is a basic coup model 3.4 sfi standard trans in it. is there any reason why it doesn't have them or am i just a fool and looked over it when i bought the car? it runs great. doesn't seem to have any problems but want all your info if u can help.
HAS:
Now its missing:
2 fans
Thanks for the advice. This car actually has 2 cooling fans, idk y, might have had some stuff done to it, i'll look it over but It does have 2.
TY for the help
ur all right!
I'm sorry, I looked into my fan and here the car did originaly have the single fan. you were right. I have a double insulated But only the one is running even when i put a relay in the fuse box. But I picked up the relay for the fog lights and fixed prob just like you guys had said, thanks for helping me out. i just wasn't sure about it and i know it was kinda a dumb question. ty n Later
The TCS/ASR was for the Z28 model. It is traction control dont worry about it. The second fan if installed correctly will only come one with the engine temp hitting a certain level or the A/C is turned on. Jump the switch poles of the relay socket and see if the second fan turns on.
Massey
Massey
rakoolo
10-04-2008 12:49 PM
