Rear Diff
I am gonna change out the fluid in my rear diff and I need a few pointers. 1st, for my car does the rear diff require any of the GM additive? I have heard that it does and doesnt. 2nd, should I use synthetic? I think I will use it but I am curious what you guys think. I appreciate the help in advance.
The LSD friction modifier "additive" prevents the posi clutches from getting gummed up, which can make the rearend chatter in the turns.
Open diff: use synthetic or conventional oil, but the additive would be a waste of money.
Clutch style posi/LSD: use conventional oil with the additive.
Torsen style LSD (no clutches), use synthetic or conventional oil. The additive technically isn't needed, but GM issued a TSB that recommended using the additive to quiet down or prevent some noise that a small number of owners complained about.
Why not synthetic in the clutch style posi? Because you want the clutches to grip, not slip.
