Ready to put it back together
Old Nov 29, 2009 | 09:58 AM
Vandee's Avatar
Default Ready to put it back together
Well im finally read to put the motor back together and i found this diagram and i wanted to make sure this had the right sequence and torque specs
11ft lbs of torque on the lower bolts
Bolts 1–10, in sequence: 11 ft. lbs.
Coolant outlet bolts: 20 ft. lbs.
Side bolts: 22 ft. lbs.
is all this Right?
Old Nov 29, 2009 | 09:49 PM
what motor and yr?
Old Nov 29, 2009 | 10:19 PM
By looking at the "3800" marking on the intake plenum, I'm gonna take a wild guess and say a 3.8. Wouldn't the specs be the same between years?
Old Nov 29, 2009 | 10:25 PM
i dont have any info on the 3.8. lol. time for sleep.
Old Nov 29, 2009 | 10:28 PM
Nitey-night. And don't let the bed crabs bite!
Old Nov 30, 2009 | 06:20 AM
osduck5's Avatar
That is the same info that I used when I did mine.
Old Nov 30, 2009 | 08:28 AM
Vandee's Avatar
Really? well im thinking that the torque on the upper intake is to high cuz i snapped a bolt.......talk about unlucky....
Old Nov 30, 2009 | 09:14 AM
at 11 ft lbs? or the 22? id say the bolt was cracked already or has had some heat stress. pick up a easyout set and some new bolts.
Old Dec 1, 2009 | 10:26 AM
Vandee's Avatar
yeah at 11ft lbs its snapped but it snap off high enough that we could get a vicegrip on it and spin it out
Old Dec 1, 2009 | 11:28 AM
Are they tiny bolts, because 11 lbs. isn't a lot of torque. Is your wrench reading accurately too? I don't trust my clickity-click torque wrench way down on the low end of the torque spectrum. It doesn't always click when it should. But, I also have an inch lb. torque wrench for reading the more intricate small bolts. You might want to use a beam type torque wrench for the small stuff instead (assuming you were using a clicker).
nmallory56
Aug 3, 2009 05:31 PM
359pete
May 4, 2007 11:12 AM
loar
Oct 15, 2004 10:42 AM
