Radiator leaking around neck
Old Sep 30, 2009 | 07:30 PM
osduck5's Avatar
Default Radiator leaking around neck
Does anyone else have troubles with their radiator leaking under the radiator cap? Car is not overheating but every other day, I have to replace the coolant. I have replaced the cap but it still leaks. The overflow tank has been full and nothing is being drawn out of it when the rad gets low. I placed my hand over the rad neck hole when car is warm and could feel the vac drawing in the coolant from the overflow tank. I used a pair of channel locks and bent the locking tabs on the cap so that the cap will fit pretty darn tight. I will check in a day or so to see if that seals the neck. Does these radiators require the black plastic cap OM part in order to seal properly?
Old Sep 30, 2009 | 07:38 PM
machine1999z28's Avatar
Dose the inside of your rad. neck have corrision or a funky build-up at the sealing area.
Old Sep 30, 2009 | 07:45 PM
osduck5's Avatar
I have cleaned the inside of the neck as well as the top of the neck where the gasket part of the radiator cap would seat. I cannot feel any cracks or burrs around the top or the inside of the plastic neck.
Old Sep 30, 2009 | 07:50 PM
IDK man, All I can think of is poor contact at the seal area, or a small crack that you just havent noticed yet. I'm kinda stumped
Old Sep 30, 2009 | 07:54 PM
osduck5's Avatar
Yeah me too! I just wanted to ask on hear before I dropped $150 bucks on a radiator but I guess that is cheaper than overheating and ruining an engine. Thanks anyways!
Old Sep 30, 2009 | 08:05 PM
^^^^ True! Have you had it pressure tested?
Old Sep 30, 2009 | 08:16 PM
osduck5's Avatar
Not yet.
Old Sep 30, 2009 | 08:24 PM
I think I would try that b4 I bought a new rad. That way you can see if it will hold press. and possibly find the leak
Old Oct 4, 2009 | 09:26 AM
KawasakiJ14's Avatar
Mine had a leak right by the radiator cap on the plastic neck just below the cap. I tried appoxy but the seal won't hold. i would spend the cash and just replace the damn thing.
Rocketray
Jun 25, 2012 11:24 AM
67camaroGURL
Oct 15, 2010 01:00 PM
62rampsidekid
82-92 V6 Tech
Jul 3, 2010 08:48 PM
1994z28
Jan 1, 2008 02:27 PM
pdpallen
Oct 28, 2006 06:02 PM
