question
RE: question
This Stage 3 PerformancePac™ contains the following items:
[ul][*]High-Flow Air-Box Lid (21045)[*]Cold-Air Induction Package (21033)[*]High-Flow K&N Air Filter (25012B)[*]F-Body Smooth Bellows (23065)[*]Modular Loud Mouth™ Exhaust System w/2.5" Dual/Dual Tips (31042)[*]85mm High-Flow MAF Sensor (23060)[*]DiabloSport II Programmer with SLP Custom Tuning (27007T)[*]1.85-Ratio Rocker Arms w/ Springs & Retainers (51186)[*]Tuned-Length Long-Tube Headers with Aluminum-Ceramic Coating (30052)[*]Header-Installation Kit (30054)[*]High-Flow Catalytic Converters (31037)[*]Stage 3 Fender Badges (pair) [/ul]
so am i better off just tellig myself no and walking away completely, or should i opt for like a stage 1 or 2 instead?
RE: question
"Take the guesswork out of upgrading your LS1 F-Body, with the PerformancePac™ from SLP Performance Parts. Each Stage 1 package comprises a group of jointly engineered induction and exhaust components, all of which work together to significantly improve performance without adversely affecting drivability."
These performance packages are for the LS1. You have a V6. I would tell myself no.
