Quarter stick shifter install
Does anyone have one of these shifters in their car?
http://www.summitracing.com/parts/HUU-3160001/
This is for my daughters 99 V6 Camaro. She like the looks and so do I. I wanted to find out if you modified the stock console, created your own console and how the job turned out. Any pics of it would be great!
Thanks in advance.
Thanks in advance.
I dont typically dabble in automatics but it may not be appropriate for your application. that shifter is designed for the powerglide and turbo type trans (TH350 is usually referred to as a turbo 350 right?)
what transmission is in the 99 v6? You may be able to jimmy rig it and lose functionality of the lever.... but that is just me being imaginative. I don't even know if it will bolt up.
Yes, you have a 4L60E (4 speed). That shifter isn't gonna work on your trans, it's designed to work on 2 & 3 speeds. The detents won't fall into the same place as what you need, not to mention it probably doesn't have enough overall travel to go from 1-park.
TH400 is still a 3 speed. It appears that Summit doesn't carry this model for the 4l60/700R4: http://www.go-fast-parts.com/5734752.html
I don't see why not. The 700R4 is the same trans as the 4L60, just by a different name. The 4L60E is the electric shift version (in the valve body) of the 4L60, but physically still a 4 speed. The one thing I can't tell you is if there is any difference on the trans linkage between the two. I would call and ask a Hurst tech directly.
Message back from Jegs...
Hello
Thank you for giving Jegs the opportunity to assist you with your technical question.
I am afraid Hurst nor B&M offer a shift to fit the 4L60E transmissions.
Should you need further assistance please feel free to contact us.
Sincerely
Bob Grace
Technical Sales Representative
Hello
Sincerely
Bob Grace
