pcv valve on 3.8
Does the 3.8 on camaros have a pcv valve and where in the heck is it located. I have looked but it is sure hiding good and wanting to check it out
Thanks John |
RE: pcv valve on 3.8
Yes. Look on the intake manifold. It is covered with a black diamond piece.
Thanks for the info i will look if my son ever comes home long enough for me to open the hood
John |
No problem. Most vehicles I have owned, the PCV valve is on or around the valve cover. This one is strange to me.
the pcv is located on the front driver side of the motor and it has two metal tubes going to your upper intake manifold on the top right side above your water outlet and the other into your headers or stock exhaust manifold. hope i helped, im looking to eliminate mine because the metal tube to my header is messed up and has an exhaust leak but i dont know where i can have my computer tuned for it so for now its on.
ORIGINAL: corruptkid29 the pcv is located on the front driver side of the motor and it has two metal tubes going to your upper intake manifold on the top right side above your water outlet and the other into your headers or stock exhaust manifold. hope i helped, im looking to eliminate mine because the metal tube to my header is messed up and has an exhaust leak but i dont know where i can have my computer tuned for it so for now its on. |
i am an idiot, i even went to pep boys to get the gasket for it and i asked for the egr gasket, i just got confused when i read the message i guess, my apologies
