PCV System HELP!
Old Oct 2, 2008 | 08:45 PM
Whitehoss02's Avatar
Default RE: PCV System HELP!
Hey man i appreciate the help, but that wasn't what i was looking for - I've been doing some research on LS1 tech - about turbo crankcase pressure - they seem to be puttin a breather on passenger side, catchcan with breather on other side - and another line from catch can back to induction side of turbo in the rear - Wouldnt that cause a resido in the return pipe causing corosion and failing the MAF? Need help here bro.
Old Oct 2, 2008 | 09:09 PM
02StanGT's Avatar
What you are describing sounds like you are putting boost to the crankcase through the catch can line back into the valve cover. I would think that if the PCV is plugged, and all you had was a breather, that would be fine enough. Did that not work for you?
Old Oct 2, 2008 | 09:14 PM
The logic behind my setup was to have - Passanger side Breather - Vacume..........Driver side line to catchcan and breather - To release preasure to atmosphere and catch oil. I havent tried this yet I am asking to make sure this system is correct.
Old Oct 2, 2008 | 09:41 PM
02StanGT's Avatar
See if my crude drawing shows what you are talking about
Old Oct 2, 2008 | 09:56 PM
Ight bro this is what I meant - Let me know what you think - this is what the manufacturer recommended... but I'm not sure.
Old Oct 2, 2008 | 10:07 PM
02StanGT's Avatar
That looks like it would work. I would get some more opinions just to be sure.
camaroguy457
Sep 24, 2011 11:20 AM
Carl Dan
LS Series Tech
10
Oct 20, 2010 05:48 PM
Crunchy
Dec 12, 2008 10:15 PM
ninetysixyenko
Jul 9, 2008 04:55 PM
69camaro1
Oct 11, 2006 03:59 PM
