over heating problem?
#33
ohh yea i did replace the relays too. they only thing i can think of that could be wrong is that the radiator is bad or the head gasket is bad or the head is cracked, but the car isnt smoking at all so im hoping for the radiator to be bad.
#36
Look in your radiator - does it look muddy or clean? Did you ever reinstall the air scoop under the bumper? Fans working?
#40
Well after about a month a leak developed from the front of the intake manifold bad lower intake gasket, well..top of the motor needed to come off, and while the job was being done my mechanic found that the assembly that the heater core hoses flow through was clogged due to gelled dexcool and some radiator stop leak (previous owner?)
There are two tight 90 degree bends in there that the water flows through and are small in diameter and one is a small plastic tube that runs into the front of the lower intake manifold the other is just below the heater tubes and enters right next to the water pump.
This assembly has the belt tensioner mounted on it and it is all one piece tensioner and is all one piece, it was clogged and need to be replaced because the plastic tube broke ($90 in case you are wondering). So we think the clog in this piece caused the gasket to go.
New gasket and tensioner/water jacket thing?? fixed it....for a while but now the engine went I am not sure if they are related, because I am dong the engine swap now and have not torn down the bad motor.
If you are lucky maybe you can get that piece off without breaking it and clean it out, also check that plastic tube for leaks.
Good luck
