OIL GAUGE
OIL GAUGE
is it just my car or does everyones do this... i have a 96 camaro rs and the oil gauge goes up when im actually moving, but when i come to a stop it goes down.. not all the way but a little lower than half way.. and the gas gauge does the same... does anyone know why?
RE: OIL GAUGE
Oil pump isn't spinning as fast at idle, therefore the pressure isn't as great. Your gauge is fine. When slowing down the fuel sloshes to the front of the tank due to momentum. This makes the level look lower to the sending unit, therefore your gauge will read that much lower. Your fuel gauge is fine, unless it's going from full to less than half.
RE: OIL GAUGE
Your fuel guage is ****tin the bed. Its a common problem. The sending unit is sending wrong info to your computer thats why its moving. Just ignore it, to replace it you have to also replace the fuel pump, its a one peice unit. Roughly $450. for the part. And for your oil pressure guage, dude, read a book.
RE: OIL GAUGE
Oil pressure sensor is bad. That should explain the fluxuating oil temp gauge. As for the fuel gauge flux, its either the same thing (fuel pressure sensor) or the actual gauge on the instrument cluster. What 02StanGT said on his 1st post about the fuel sloshing around and giving mixed readings is correct, but I'm not enitrely positve that is your problem. I ocassionally go around "S" turns at 55-60 MPH and don't notice the gas gauge pinging around +- 1/4 tank.
RE: OIL GAUGE
RE: OIL GAUGE
ORIGINAL: The Banks
