oem or stage 1??
Old Apr 30, 2012 | 05:14 PM
PedroRider310's Avatar
Default oem or stage 1??
Hey I got a 2001 3.8 manual and I need to change the clutch I just wanna know is there a big difference between oem and stage 1 clutch kits? I would go with oem but the stage 1 I found is cheaper than oem which one will last longer is basically what I'm wondering??
Old Apr 30, 2012 | 09:25 PM
Does anyone know anything I kinda need to know asap??
Old Apr 30, 2012 | 09:40 PM
What manufacture? The market is flooded with cheap china made clutchs. You really want a name brand clutch. And don't fall for the AC delco clutch it one of theses cheapy china clutchs also. When I was searching I was thinking about getting one of these cheap clutchs until I found some reviews. Everyone of the cheap clutchs you can find horror stories of guys that did not make it 3 month and guy that even brand new they slipped. Even some of the name brands really skimp on the V6 clutchs. Spec makes a good LT1 clutch but I have heard nothing good about their v6 clutchs until you get tot the stage 3 clutch
I went with the Centerforce duel friction clutch. It was the only clutch with a OEM type feel and had good review from everyone that had it.
Old Apr 30, 2012 | 09:53 PM
I thinks its f1 racing...I'm looking for the cheapest clutch money wise but I want it to last too...u think it would go better to go with something oem or should I go with a stage 1 racing clutch...supposedly its better than oem but I really don't know
Old Apr 30, 2012 | 09:55 PM
Failed Devices's Avatar
Just go OEM.
Old Apr 30, 2012 | 10:00 PM
just outta curiosity why would oem be better to go with?? Let's say I went ahead and put the stage 1 on what exactly would be the differences that I would see??
Old Apr 30, 2012 | 10:25 PM
You already know the quality of the oem clutch, its lasted you quite a while too no? Why not get it? You aren't making massive amounts of power that would require a stronger clutch. Differences will be in feel and stiffness.
If I wasn't going to go OEM, it'd be Monster or Centerforce.
Old May 1, 2012 | 04:30 AM
Well actually I bought the car recently and the clutch went out right as I got home the same day I bought it so I really don't know how long it lasted and yah I've heard the higher stage clutches do feel stiffer but I've also read the stage 1 is basically like the oem...kinda too late now already bought the stage 1 clutch hopefully don't regret it
Old May 1, 2012 | 05:34 AM
The F1 is the exact clutch I warned you about. I hope you have better luck then most people do. You need to be very carful during break in, Once it is install expect it to be very soft. Until you can afford a real clutch drive it like your grama would.
Old May 1, 2012 | 03:10 PM
Yahh I hope so too I've read about people that had no problems with it and some that did so I hope I do get lucky thanks for the advice
Rock Chalk
2010+ V8 Tech
Apr 27, 2014 08:23 PM
deyem1
2010+ V8 Tech
27
Jul 30, 2013 08:38 PM
TBenner80Z28
May 2, 2010 04:11 PM
SScamaro22
VS
13
Sep 25, 2007 02:01 PM
sewerrat
May 12, 2007 10:19 PM
