Not Starting: 97 3800 5-Speed
Old 07-21-2011 | 02:58 PM
BasicConcepts's Avatar
Technical User
it could be in the wiring not the switch itself like i said try jumping the ignition wire on the starter to the power that will bypass everything you still need to put the key in and put it in the run position
Old 07-21-2011 | 04:24 PM
ZZ04's Avatar
Do you mean jump the ignition wire on the starter switch?
Old 07-21-2011 | 04:58 PM
3800camaro's Avatar
He means hook a wire up to the positive side of the starter and the other end to the battery. Hook to the battery last so that you can disconnect once it starts up.
Old 07-21-2011 | 05:15 PM
ZZ04's Avatar
Already done. Starter/solenoid tested fine. The problem is the fuel injectors are not getting power which appears to be a security system related issue. Bear in mind the car doesn't start even when attempting a push start.
Old 07-21-2011 | 05:18 PM
Technical User
no jump the power to the starter to the little wire you can use a screwdriver... basically when you turn the key it send power to the little wire engaging the solenoid much like a remote for an amp
Old 07-21-2011 | 05:22 PM
Technical User
Old 07-22-2011 | 08:53 PM
hevymetalg's Avatar
Def and vats issue, it's prolly a wire off on the ingnition cylinder that came off.
Old 07-26-2011 | 08:22 AM
ZZ04's Avatar
I've come to that conclusion as well. I considered doing a VATS bypass but I'm not to fond of it; making the car easier to steal, plus it kind of has a feel to it like I'm "rigging it" instead of actually fixing the problem.
I'm already in the process of replacing the ignition cylinder. I'm taking my time with it because I'm in no hurry to get it done, plus I have to wait until my next paycheck to order the cylinder (not to mention the mosquitoes are bad this year in FL and I can't work outside for very long). Fortunately the Camaro is not my daily driver so I can let it sit if i have to.
I have the steering wheel off already and I'm in the process of removing the turn signal switch. I'll keep everyone posted as I get the work done.
-ZZ
Old 07-26-2011 | 08:25 AM
Technical User
be careful with the highbeam theres a piece of plastic that will just fall out
  #20
Old 07-26-2011 | 08:00 PM
ZZ04's Avatar
Thanks for that extra info. I probably would have missed that!
Quick Reply: Not Starting: 97 3800 5-Speed
