not Starting?
i have a 3.4L 95 camaro. today i was goin to move it so i can get it picked up sso it can be taken to get its oil pan fixed. I started it up and it was running different. And then it stalled out on me when i was moving it. My buddies and i checked it out. And so far we know its not the battery cause we charged it and its fine, its probably not the alternator, and there is being fueled delievered since we smelled it and that was fine. and when we tried to pop the clutch it wouldnt start. What could it be??
my old geo tracker did the same thing. the ECU or on-board computer went out. i had all those same problems. if you spray some carb injector spray into the throttle body, itll start. itll run rough but give it time to warm up. this is jus a temp. fix so you can get whatever you need done.
ok thanks...the onlyt thing is that i called my mechanic and they already took it. so i guess it will be fixed then. Thanks, when i talk to him ill tell you if you were right or not.
turns out that since i bought the car 3 months ago and was waiting till after winter to register it, the car just need a fine tune up, and a new oil pan (which i knew it needed).
