is nitrous to much?
is nitrous to much?
i was thinking about getting nitrous for my car but being how it has 170,000 miles i was a little scared. do you think the motor would support? also all the car has is an exhaust. its a 5spd and if i did end up with spray i probably wouldnt go over 75 wet with a nx system, is that to much?
Dry only for 6s i believe..you would for sure need to replace head gaskets with some high quality ones..they'll be the first thing to go..i honestly would rather go with an intake and some engine work or even posi rear end before i did nitrous..
You need to prep for Nos. Clutch, exhaust, head gaskets. 50 HP you can do Dry and 75 HP you can do dry if you upgrade your injectors. You would want a RPM and clutch safty switch.
With those miles I would want to rebuild the motor before I did Nos.
likearock91288
08-13-2007 09:18 PM
