New Problem
Old Jul 9, 2008 | 05:17 PM
TV's Avatar
TV
Default New Problem
2000, 3.8, 52,000 miles
Sup ladies, Ive noticed a problem lately. My lights dim and my blower fan slows down when i am decelerating as the car down shifts, also when im just sitting in the driveway shifting from drive to reverse. The battery guage drops into the red but it only lasts for a second or two then its fine, my tach doesnt change so my idle isnt dropping that much as i shift any suggestions ? thanks in advance.
Old Jul 9, 2008 | 07:39 PM
MusicMan's Avatar
The Jazz Man
Default RE: New Problem
might be the altinator, but that's just a guess from what you said.
Old Jul 10, 2008 | 10:43 AM
pem's Avatar
pem
2002 3.8L
I am getting mixed gas readings, I was putting gas last night and Inoticed that the coverunder the cap which leads to the tank isnot flush with pathway.What is that partcalled? and can it have anything to do with the gas readings i.e. (gas evaporation?)
Old Jul 10, 2008 | 03:18 PM
Pem, you should start your own thread for this.
You're talking about the restrictor in the filler neck, and it's supposed to be there. Years ago, when leaded fuel was used, the pump nozzle for leaded was a larger diameter. When unleaded cars came out, they put a restrictor in the neck and made the unleaded pump nozzle a smaller diameter. That was done to prevent anyone from putting leaded fuel in an unleaded car.
Start your own topic and we can address your other issue, that way nobody will scream "hijack"! [8D]
Old Jul 10, 2008 | 05:09 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
to the op. its either your alternator or a bad battery take it to a auto parts store and they should be able to test them both.....then you can have them repalce what need be or do it yourself....
Old Jul 11, 2008 | 05:55 PM
TV's Avatar
TV
Autozone checked tha battery and the alt. ... They say there both fine.
I noticed yesterday that there is no problem until the car reachesits normal runningtemp. My worry is this may have something to do with the tranny because this only happens when the car is downshifting, and when i shift from reverse to drive and from drive to reverse .. back to square one i quess
Old Jul 12, 2008 | 05:07 PM
Chappie99's Avatar
Is this with your A/C on? If so, this is normal. Its caused by a draw against your alternator from your A/C compressor.
Old Jul 20, 2008 | 06:03 PM
TV's Avatar
TV
Well my a/c has been on but i dont think its from the compressor. It only happens when the car is down shifting or when im shifting from reverse to drive or visa versa. ... im going to go out there tomorrow and check it out. Ill turn off the a/c and see if theres a change ... thnks
Old Jul 23, 2008 | 07:00 PM
TV's Avatar
TV
Na, no difference. A/C on or off still does the same thing but only when the tranny is shifting. i guess ill have to break down and take it somewhere.
Old Jul 23, 2008 | 07:52 PM
Fortee's Avatar
Your transmission shouldnt have anything to do with it.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
