new circuit or fuse?
Old Apr 8, 2008 | 06:31 AM
facingxtinction's Avatar
Default new circuit or fuse?
I have an 01 camaro with power windows and locks. Every once in a while, when i hit a bump the radio looses it's power, then eventually comes back on. Sometimes it comes back on within amatter of seconds, sometimes minutes, sometimes it doesn't loose power at all. What concerns me, is when the radio does loose power, so do the power window controls on both doors. Anybody have any ideas on where i start with this one. I don't think a fuse would be it, but open to all suggestions.
Thanks...
Old Apr 8, 2008 | 12:44 PM
Ghost32's Avatar
Default RE: new circuit or fuse?
Did you put a after market radio in or is it factory? Sounds like some along the lines some is touching and shorting out.
Old Apr 8, 2008 | 07:42 PM
it still has the factory system...That monsoon crap or whatever.
has done it in 2 days, but just my luck it will do it right before it rains, and i won't be able to get the windows up.
Old Apr 8, 2008 | 07:57 PM
02StanGT's Avatar
Has it done it at night? Just curious if some of the interior lights (dash and such) go out as well. Everything you listed comes of the Body Control Module (BCM). You might check the fuse, but if it comes back on, I don't think the fuse is it.
Old Apr 8, 2008 | 10:47 PM
May be a bad or dirty connector on the BCM.
Old Apr 9, 2008 | 06:33 AM
it has only happened in the day so far. Hasn't happened in a while now though. I can tell you this,
when it happens i can hit the vinyl console just below and on the right side of the radio and the power comes back to the radio and windows....I have to hit it kinda hard though.
izayuhgawd
Nov 21, 2011 09:24 PM
Schappie9
Sep 17, 2011 11:43 PM
ladybridgeport
Apr 5, 2010 08:44 PM
Redeemed
Oct 4, 2007 01:39 AM
