needing help
needing help
i recently had a new engine put in my 97 camaro its a 3.8 5 speed engine runs fine but now all of a sudden the clutch is really stiff and won't engage would this be a slave cylinder you can still go threw all gears it just wont engage, i need advise please, thanks
a regular clutch last about 4-7 years. your car old is that means your clutch has been slipping. You might want to get a new clutch
If you slave cylinder is bad, your clutch wont be stiff, it would be the opposite, it would be completely loose
does anyone know how to fix the speedometer mine is not working since I've had the engine put in does any one know where the speed senors are? I have a chilton book but it doesnt say anything about the vvs, thanks
