need help again..
i feel dumb for posting so many threads but if its not to much to ask i was wondering if you guys could help with me with a few more problems? first on the list is my heater. i flushed out the core but it still doesnt work. and the second is my instument cluster doesnt light up anymore. i my radio was acting up and i pushed my back about 1/4 of an inch and they just shut off. i dont know what it could be i checked the fuses, the bulbs, and the wireing but still nothing. any help would be appreciated. thank you all
Lol never be afraid to ask for help man. Regardless of how many threads you make.
As far as your heater goes, I'm not really sure what was wrong in the first place. Is your car overheating any?
As far as your gauges and radio go, it could be the body control module gone bad. Mine went bad in my Camaro and I replaced it. Unhook the battery for about 15 minutes and let them all reprogram themselves and see if that helps. Nothing like a hard boot to clear them babies out!
If you could explain the heat issue more, I could help a little more.
Yep, need more info on the heater. Is the heater fan blowing? If so, where, windshield area, vents or floor? Can you hear the heater door moving when you change the temp control from cool to hot? How much flow was you getting out of your heater core when you flushed it?
and as for the reset ill do it after i get home from school tomarrow and let you know what happens. thanks again.
Might want to check to see if the cable on the cool/hot **** is actually working the heater door since it is hard to turn. You can raise the hood and feel the heater hoses at the firewall to see if they are both warm to see if coolant is actually flowing through the heater core.
ok so today i checked to feel my coolant hoses and the coolant hoses that go to the radiator were burning hot and the other ones to the heater core were not cold but they werent hot at all. so does this mean i dont have any flow whatsoever?
They will not be as hot as the radiator hoses. You could have a partially clogged heater core. What is your engine temp? I am assuming your thermostat is opening and closing normally?
ok. and it usually stays at i think 180-190(the first notch above 160)
Judging by this your core is clogged or your heater door isn't opening. Or both :P
