Need help!
Old 03-30-2009 | 08:08 PM
redstarz808's Avatar
Default Need help!
i recently went to change my oil on my 94 v6. and in doing so, found out i had a leak afterwards. got under the car and checked it out. the housing that the oil filter screws into, that is attached to the block. the gasket in between the block and the housing was what caused the leak. bought a new one, and went to change it out. the mounting bolt that mounts the housing to the block also has a ring of some sort on it. its not a oval ring, more of a flat, sort of like a gasket i guess. that also was broken so oil is still leaking out. i have called all kinds of part shops and cant find it. does anyone know what i am talking bout? and does anyone know where i can get a replacement? i really need it as soon as possible.
