need help
Old 04-30-2008 | 09:26 PM
red99camaro's Avatar
Default need help
Ok I have a 2001 v6 camaro I recently just put new plugs and wires in the camaro I put bosch platinum plugs in it and it came up with cylinder 5 misfire so I put ac delcos in and it still has stuttering and hesitation under acceleration, does anyone have any ideas?
Old 04-30-2008 | 09:39 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: need help
did you gap the plugs before you put them in according to factory specs? improper gap can cause lots of issues
Old 04-30-2008 | 09:59 PM
Yeah I gapped them to 0.060 thousandths is that right?
Old 04-30-2008 | 10:22 PM
evilkal's Avatar
I thought it was .050?
Old 05-01-2008 | 07:35 AM
so I need to regap my plugs to 0.50 ???
Old 05-01-2008 | 11:02 AM
02StanGT's Avatar
.060" is right. There are labels on the radiator cover. One of them tells you what the gap should be.
Old 05-01-2008 | 10:22 PM
evilkal's Avatar
Ignition coil packs then plz?
Old 05-02-2008 | 11:35 AM
Ok So I need to check the ignition coil pack for cylinder 5 how would I go about that? Can Autozone do that? I had codes ran and it pulled a p305 cylinder 5 misfire I took the old bosch plugs out put ac delcos in and it ran lil better but when you floor the gas it stutters and hesitates under load, but cruising it drives fine...
Old 05-02-2008 | 12:29 PM
maguilar496's Avatar
Same Thing happened to me, I would get misfire under load. It turned out to be the coil pack. I took mine to autozone and they told me the coil pack was fine beause they checked for resistence. They can only tell you when it is completely out not when it is just malfunctioning. I didn't listen to them and I took the risk bought it and it fixed the problem. [8D]
Old 05-02-2008 | 05:35 PM
02StanGT's Avatar
You could just swap the coils around, and if you get a misfire on another cylinder, then it's probably your coil pack.
