Need Help
Need Help
So i need help. I just picked up a 94 camaro 3.4l v6. All seemed fine until today. I was driving at normal speeds and all of sudden the cars engine temp skyrocketed. I pulled over to examine the problem only to realize there was no coolant in the resvoir or raditor. So i quick ran and got some coolant and water and put it in, but as i poured i heard it pissing out on the ground. I looked under neath and the coolant was leaking very fastly. I could not pinpoint from where though. But as it pours down it does so around the oil pan in a steady stream. Does anyone know what it could be?
RE: Need Help
Well it was like a -10 degree day so it might be the resvoir. I tried to get under the car but i cant see too much. Its defintely not the radiator draing plug, becasue the leak is coming further back than where the plug is located. I have yet to actually jack it up and get serioully under their beacause of the snow and cold wheather and the fact that I live in an apartment complex with no garage.
Need Help
So i got up under the car and had a buddy poru water into the radatior to see where the leak originated from. It comes from the passenger side rear part of the engine, Right next to where the oil pan connects to the block. I can see excatly where its coming from yet though. Any ideas, someone suggested a freeze plug?
