-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   my pinion seal (1998 V6 CAMARO) (https://camaroforums.com/forum/93-02-v6-tech-14/my-pinion-seal-1998-v6-camaro-26157/)
hevymetalg Mar 26, 2008 06:14 PM
my rear is leaking. its the pinion seal i think, but it started to make a noise and the oil was real low so if i change the seal and fill it back up will the noise go away or do i need to get a new differential thanks for your time.
Labyrinth9 Mar 27, 2008 08:34 AM
RE: my pinion seal (1998 V6 CAMARO)
replace your pinion seal, its a little annoying you have to make a tool usually. but you dotn need a new differential unless you have wrecked the diff by running it for an extended period of time with no lube.
hevymetalg Mar 27, 2008 06:31 PM
what do you mean make a tool? and will it still make the noise?
