my pinion seal (1998 V6 CAMARO)
Old Mar 26, 2008 | 06:14 PM
hevymetalg's Avatar
Default my pinion seal (1998 V6 CAMARO)
my rear is leaking. its the pinion seal i think, but it started to make a noise and the oil was real low so if i change the seal and fill it back up will the noise go away or do i need to get a new differential thanks for your time.
Old Mar 27, 2008 | 08:34 AM
Labyrinth9's Avatar
Default RE: my pinion seal (1998 V6 CAMARO)
replace your pinion seal, its a little annoying you have to make a tool usually. but you dotn need a new differential unless you have wrecked the diff by running it for an extended period of time with no lube.
Old Mar 27, 2008 | 06:31 PM
hevymetalg's Avatar
what do you mean make a tool? and will it still make the noise?
Camaro 69
May 1, 2012 12:00 PM
98ssconv
Mar 15, 2011 07:28 PM
freswick
Nov 13, 2009 09:07 PM
thetal1
Oct 8, 2009 12:15 PM
rsh3429
LS Series Tech
May 8, 2009 06:57 AM
