Misfire
ok enough is enough
ive changed the wires and plugs
IAC and TPS
Camshaft Sensor
Belt Pulley
Fuel FIlter
I got my Coils checked and they were good
could it be my control modecule?
i hear the misfire coming from the driver side
if anyone has any ideas feel free to list them
IAC and TPS
Camshaft Sensor
Belt Pulley
Fuel FIlter
Are you sure it's a misfire and not an exhaust leak you're hearing? If you know where the "misfire" is pull the plug, and compare it to the pictures of plugs in your Hayne's manual. The plugs can tell you alot about your engines performance.
i changed the plugs but im kinda thinkin exhaust leak
i hear the ticking noise when i accelerate or idle which i kno is the exhaust( my exhaust sucks) but when i step on it it makes a poppin noise so could that be the exhaust leak too?
it does not pop at low rpms like 2500 only at high when i floor it
