ls1 throttle body on a 3800?
ok i seen this part but i cant find it! its for a camaro. its a throttle body adaptor that allows you to run a ls1 throttle body on a 3800. anyone know where i can find it?
Why would you want to run an LS1 throttle body? Your's is more than plenty. All I could find was one for the supercharged 3.8. http://www.zzperformance.com/grand_p...=256&catid=113
Your TB is more than enough for any kind of power you're going to make NA or even with a decent turbo. I know many people running turbos at 15 PSI on the stock TB with no problems making almost 500 hp so... Basically, don't waste your money.
I'm not even talking about the ram air part... I'm talking about the LS1 TB lol. There's no way it benefits any set up on a 3800. You're actually probably hurting because intake velocity would be WAY down so you'd negate any "RAM AIR" effects if ram air actually worked lol.
please explain more...its gotta work i hooked a genesys scan tool up to the car while driving and it not only improved airflow and lowered intake temps
dude id be better cause i have a 2000+ intake. if i used that intake with a straight bore plus a ls1 tb id be able to use smooth bellows and it would be just a nicer setup. no muss no fuss
