lowering springs....good or bad?
Lowering springs are a low cost way to lower the car, but by necessity are much stiffer than stock units, and when used on the front end they can cause undesired changes in steering geometry, and handling (camber changes and bump steer, among others). A better way, which is also more costly, would be to change to lowering spindles or hubs. However; this may present a problem with newer cars, that use hubs instead of spindles, as lowering hubs are not commonly available.
That being said, as low to the ground as Camaros are, dropping the car lower will make it difficult to drive around without the car body hitting the ground on rough and uneven surfaces.
I have not driven my lowered 93 yet but the forward frame rails are beat and both lower, rear fender mounts are going to need attension.
Please tell me your not serious? Lowering your car a moderate amount should have very little affect on speed, generally the less air under the car the better the aerodynamic properties are, which is why a 1 to 2 inch drop and a small front lip will tend to increase gas mileage a bit(maybe 1mpg better on the highway). Perhaps if you mount a GT style wing, full body kit and slam the car so you have a 100+ lbs of downforce you may see a loss in top speed. Cars are generally designed to break through the air as best as possible and force the air up over the car. Race cars have rear diffusers to basically remove the air that gets under as that is counter productive, rear lips will actually hinder handling when taking cars to thier limits as air gets trapped there. Sideskirts are also helpful to send more air around the car. Lowering the car may actually increase top speed, I'm not an expert just using common sense, but you won't ever notice it on the street anyway, and you shouldn't be hitting 120+ on the streets anyway.
To fully answer your question, no you will not a see a loss in speed, the car may be a bit stiffer and may grind on inclines/potholes daily driving it. Make sure you upgrade the shocks with the springs though, and depending on how low you are going you may need an adjustable panhard bar. Good luck and do research on what parts are best. SLP makes a kit for our cars that replaces the shocks/springs with stiffer parts and I believe drops the car around 1-1.25 inches.
