Low end throttle noise?
Old 01-12-2010 | 08:22 PM
Envisi0n91's Avatar
Default Low end throttle noise?
Do you guys get a rumbling sound when you're in low RPM's (2-3 especially) and give it full throttle? Its a watery rapidly repeating sound. I drive a 2001 5 speed 3.8 and I've been thinking its normal. Do any of you get the same noise?
Old 01-13-2010 | 03:51 AM
evilkal's Avatar
Watery... Rapidly repeating... Interesting description you got there lol. I get a rumbling sound though... My exhaust
Old 01-13-2010 | 09:44 AM
Usually you get a sort of a sucking moaning noise if you don't have a noise baffle on the intake. Something like when a 4 barrel carb is at WOT. lol
Old 01-14-2010 | 12:36 AM
camaro_burns_all's Avatar
VIP member
air sucking in through the intake maybe?
Old 01-17-2010 | 10:56 PM
osduck5's Avatar
Any SES codes? Check around the EGR valve. There is a gasket under it and if it is leaking, you will get some crazy noise but your engine will also be lacking performance. I could hear a vac leak with the hood raised but could not locate it. Engine was idling and I decided to spray it down, thats when I found the gasket cracked.
Old 01-17-2010 | 11:06 PM
hole in the muffler or exhaust maybe? are u feeling any vibration when its doing this.
Old 01-18-2010 | 04:39 AM
Envisi0n91's Avatar
SES code says fuel trim too low in b2. I'll check for the leaks tommorow
B_Dubya
03-27-2015 03:10 PM
B_Dubya
09-23-2014 12:01 PM
VALHAR
09-10-2013 11:20 AM
mike6208
02-09-2012 12:51 AM
buell0303
12-03-2006 12:24 PM
