LIMITER!!!!!???
LIMITER!!!!!???
B.S! ok
I'm running with a stock 2000 3.8 v6 5 speed manual... there is a stock speed limiter on there apparently.. and it pisses me off... i know my car is well capable of going over 120, in 5th I'm going 120 and the rpm is only at 4k rpm... so anyone know how to take of the governor?
RE: LIMITER!!!!!???
ORIGINAL: 02StanGT
You have to get a tune or programmer. You don't need to be going that fast anyways. People get hurt like that.
AND..you say ur car is all stock.. they put the limitor on there for a reason. uTHINK ur car can handle more
RE: LIMITER!!!!!???
dispite popular belive removing the limiter will not make your car faster.... it will still take you just as long to get up to that speed and as stan says 90% of races will never get that high so theres really no point......
RE: LIMITER!!!!!???
ORIGINAL: maroman209
x100
ORIGINAL: 02StanGT
RE: LIMITER!!!!!???
ORIGINAL: BeraniHull
Blow without redlining?
ORIGINAL: 98RCMARO
Check what rating your tires are...
If they aren't Z rated, you should never go above 120, which is where they will blow out.
Have fun.
Have fun.
