Knock on passenger
Old 11-22-2010, 12:47 PM
JordanN's Avatar
Default Knock on passenger
Whenever I start my car from a cold start, I can hear a knock coming from the top of the engine on the passenger side. When the car gets to the ~195 temp range its not as noticeable. Any ideas?
95 3.4L
Jordan
Old 11-22-2010, 02:57 PM
Massey's Avatar
my guess is a pushrod or lifter may be clogged. or a loose rocker.
Massey
Old 11-23-2010, 05:53 AM
1augapfel's Avatar
Is the noise really a knock, a heavy, deep sound? A knock usually come from the bottom end.
A lighter, sharper sound that comes from the top of the engine is usually called a tap. Think of the sound made if you tap a bolt against a pane of glass. That type of noise is usually a valvetrain problem. As Massey says a lifter with dirt in it is possible. This moise is most common following a cold start when the lifter needs to fill up with oil. The tap usually shows up suddenly and can persist or can disappear just as quickly.
If a cam lobe has worn away (or a pushrod tip) the noise will increase gradually.
An engine oil analysis (by a company like Blackstone Labs) will tell you a lot about what's going on in there. Coolant? Steel powder? Bearing material? Cast iron powder?
Old 11-23-2010, 06:34 AM
evilkal's Avatar
My guess is a sticky lifter if you're hearing it from one side in the top end.
Old 11-24-2010, 10:52 AM
xcorat's Avatar
I think i have the same problem, It's, as you said, more like a tap, from the passenger side, but not from the top, but like middle. It comes only after a cold start, and would be unnoticeable after you drive for like 400-500ft or so. Is there anyway to check what it is easily?
Old 11-24-2010, 10:59 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
cold lifter tick,, not a huge deal, but when you have the extra money id get it taken car of
Old 11-24-2010, 11:28 AM
RFxCamaro's Avatar
I had a slight tap on start up. I just did a oil change and it went away. You might be using too thick of an oil and thats why its no lubing right. On my friends mx5 he had a loud tap which was consistent at all rpms and after doing an oil change it went away asap as well.
EDIT: Even if your dipstick says full do an oil change because those damn dipsticks have lied to me numerous times.
Old 11-24-2010, 07:38 PM
xcorat's Avatar
i've been using synthetic, but someone had said i should use regular since the car has 170k on it now..! any opinions?
Old 11-25-2010, 01:38 AM
RFxCamaro's Avatar
Huh dont know if that could cause it since ive never used synthetic. Might be worth a try but let someone elsechime first.
Old 11-25-2010, 06:08 AM
Chevy101's Avatar
I've been using synthetic since I bought my car and it had 180xxx on the odometer at tge time. What weight oil do you use? I use the mobil 1 10w40
Quick Reply: Knock on passenger
