-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   Intermittent High Idle. (https://camaroforums.com/forum/93-02-v6-tech-14/intermittent-high-idle-42621/)
Gorn Sep 5, 2009 08:20 PM
I am getting a intermittent High idle code (service engine soon light). Sometimes I get it 3 minutes after I start driving, sometimes I can go 25 minutes before it comes on. At first I thought I had a linkage issue, I disconnected the cruse control just to be sure. I check the throttle cable to make sure it was not sticking. I used carb cleaner all around the linkage.
On a fresh start as long as I do not touch the gas the car idles at 850 RPMs. It will do this all day long and not set a code. When I rev the motor up and let it drop down to 1500 RPMs at a normal rate but then it seems to pause at 1500, Then it is like a switch is thrown and drop to about a 1000 RPM then slowly gets back to the 850 RPMs. The reason I do not think its a sticking cable or stick thottlebody is because of the code. If any of that mechanical suff is causing the problem the TPS would just think I had my foot on the gas and it should not set a code. Also the fact it comes and goes rules out vacuum leaks,,,, I think. I also pulled out the IAC motor and found the end was dirty and a bit rusty. Cleaning it has not seemed to help.
When I shift between gears the car does not go below 1500RPMs even if I pause. I think that is when it sets the code.
I guess all that is left is to replace the IAC motor. Any other ideas?
BTW I did just install this motor. its from a 2002 but the intake and Thottle body are all from the original motor.
z28pete Sep 5, 2009 08:47 PM
What is the code???
Camaro 69 Sep 6, 2009 01:14 AM
Take off your nifty new intake plenum. With the engine running, hold a finger over the small opening in the TB that's right in front of the throttle blade. If your idle comes back down and evens out, your IAC is bad.
Gorn Sep 6, 2009 08:15 AM
Thanks, I need to change the display on my scanner today, for some reason it did not give me a code number. 69 I can try that the only problem is most of the time its a issue is when I am driving. I have had it happen while sitting but most of the time it work ok with the car not running out on the road.
The old 2.8 used to have a problem with there TB binding up. There was a kit to fix that. Anyone heard anything like that with the 3.8.
Gorn Sep 6, 2009 04:46 PM
Well I put 60 Miles on it today and no Check engine light. I am hopeing the choke cleaner I put in yesterday did something. I also pulled the IAC motor and cleaned that. It still seems to come down in RPMs slowly but I am new the 3.8/5 speeds. It does allways seem to get back to the 850 RPMs.
Gorn Sep 7, 2009 05:35 PM
It set today, Its P0507
MusicMan Sep 8, 2009 12:45 AM
I'm curious if it's a vacuum leak.
some good info:
http://www.obd-codes.com/p0507
Gorn Sep 8, 2009 02:39 AM
some good info:
Thanks for that link. My first thought was Vacuum. But at this point I can go out and start the car and let it idle all day and it will not set the code. I would think a vacuum leak would be at its worst at idle. It only sets the code while driving. Since both the EGR and the PVC work under light load and " turn off" when going to idle I am going to start there.
