intakes?
RE: intakes?
You're not going to find one for it because they don't work well with MAF sensors.... It would normally throw a code. The best you're going to get is most likely a cold air intake.... Or if you're smart, make a DIY ram air intake and remove the air silencer and there you have a better intake than you're going to find on the market...
But it's all up to you
RE: intakes?
Fuel Injection Performance Kit - 5.7L V8 F/I - All - Carb Exemption: Y
so this will work on a 3.8. and if so do i just have 2 remove the stock 1 and change it with this 1
