3.4L bogging down @ 2K RPM
Old 03-21-2012, 01:55 PM
hetrickw's Avatar
Default 3.4L bogging down @ 2K RPM
I have a 94 3.4L that's been sitting for almost 5 years. Finally got it to idle (sounding normal), when I accelerate in nuetral and also when driving at about RPM 2k she starts to lose power, bog down, almost stall if i dont' ride the clutch. I'ver replaced the oil/filter, air filter, fuel pump, fuel filter, COIL pack, EGR valve, map sensor, plugs, plug wires, tested fuel injectors, and still the same. NO "check engine light", Smokes significanlty when I rev RPM, little at idle. Clutch rebuilt 20K ago, car/engine has 129k on it, mufflers/cat convertor fairly new. Does it sound like valve/s stuck/ burnt? not sure. thanks for any help.....
bill
Hayden
10-13-2011 08:20 PM
akleeve
10-18-2010 06:40 PM
nybowtieboy
70-81 V8 Tech
09-09-2008 01:30 PM
randolphdelpriore
05-27-2008 01:36 AM
bawrestler
82-92 V8 Tech
01-29-2008 06:05 PM
Quick Reply: 3.4L bogging down @ 2K RPM
