Insight on codes
Insight on codes
So, i took my 95 camaro (3.4 v6 5spd manual) to oreilly auto and used their obd1.5 scanner (finally) to pull codes on my car.
heres what i got:
-EGR solenoid failure for solenoids 1, 2, and 3 (codes 75, 76, 77 respectively)
-Right oxygen sensor error (code 63)
-Left oxygen sensor fault (code 13)
-Right and left oxygen sensor lean (64 and 44 respectively)
-Throttle position sensor is too low (code 22)
My friend told me the o2 sensor errors may be caused by the failure of the EGR. Looking on here for insight and second opinion too.
Also, what is the difference between fault and error, like does error mean the part may need replacing?
the car also seems to stutter on acceleration and in low rpms (1500-2000ish) every now and then, ie: sometimes it does, then i shut off the engine and restart and its fine. the oreilly guy said the throttle position sensor may cause this.
ideas?
thanks in advance.
-ian
heres what i got:
ideas?
thanks in advance.
-ian
factory service/shop manual. the only way to go. this one is spendy but is the one you want, you should be able to find a set for less if you look for a while. i got mine for 20 bucks but the 93 is a one book volume. 1995 CAMARO FIREBIRD TRANS AM SERVICE SHOP MANUAL 95 TA | eBay
