Ignition Control Module Wiring Diagram
Does anyone have the Ignition Control Module wiring diagram for a 98 Camaro with a 3.8 V-6 engine and automatic trans that shows where the camshaft position sensor signal wire is running to. I know it's running to the PCM. I need to know exactly which circuit it is running to, the C1 or C2 and at what pin cavity. If anyone has it can you please email it to me at: Chevyone@hawaii.rr.com If it can be posted here, that would be fine as well. Thank you for your support, Tommy.
Originally Posted by 3.8 V6
(Post 95790)
Originally Posted by guardian452
(Post 742012)
P.s.: Thanks for your help. |
