-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   Ignition Control Module PROBLEMS!! HELP!! (https://camaroforums.com/forum/93-02-v6-tech-14/ignition-control-module-problems-help-55933/)
jollygemini Oct 10, 2010 05:55 PM
Why is my car going through so many ICM's? I have replaced 3 in one month. At first wasn't using dielectric grease, but did on the last (after research). That lasted 2 days. I am REALLY tired of it leaving me stranded! When it cools, it fires right up and will run until it gets hot again. URGENT! I am about ready to SELL my LOVE!!
z28pete Oct 10, 2010 11:45 PM
There is no reason that they should just burn out so quickly. You may want to take a good look at the wiring and connectors and check for intermittent connections. May be that you are replacing good ECMs for no reason, except for bad wiring.
