i need help, 1994 v6 camaro no cat & no o2 sensors
Ok so I pulled all my plugs and none of them were white looking. They were all black showing sign of the engine running too rich. Does anyone know what else could be causing this.
Trying to post quick reply but hasn't been working. Pulled all my plugs they are covered in black soot, shows that all the cylinders are running too rich. I don't see any vacuum leaks or could find any vacuum leaks. Both of my o2 sensors in the manifolds seem to be okay. Any one have any other ideas why it could be running rich. I noticed I have the bosch double platinum plugs. Not sure if they are good for this car
Okay I'm going to do a good lookover today. It idle at 1k rpms. I would assume if it were a acumen leak it would be higher right? It does blow a little smoke has a pretty strong exhaust smell to it. Stronger than a normal running engines exhaust would smell. I haven't been able to get the codes yet. I need to get some one over here with a scanner. Hopefully I can get that accomplished today. Something I also noticed is I seem to be having a little exhaust smoke coming from the engine bay around the manifolds as well. Mabey my manifold gaskets rotted through I'm not sure. Im gonna try to look it all over today. Any more ideas and what is this open loop? Something I did notice is when I mash the gas pedel some and my rpms raise they don't come right back down they kinda slowly come down, this is in neutral of course.
I will check that out. Did yours seem to run rough? Mine does that it has a really potent exhaust smell. I run it for a few mins and just being around the car makes me stink like exhaust fumes.
I did the non-fouler trick.
http://forums.evolutionm.net/evo-how...ouler-how.html
It moves the o2 out of the stream of exhaust and makes it believe your cat is working. Ive had it on since October and I still havent thrown a code for my cat since.
Yep that is correct. Mine only has the upstream sensors. So far all I've been able to figure out is that its running rich. I haven't been able to get a scanner on it yet. I am going to check the vacuum wires around the intake manifold. Could a vacuum leak cause this? Pcv? Not sure if this is what's going on.
I ment to say vacuum lines not vacuum wires, I have to mention again its running so rich it that its rough, acts and sounds like a cam. I can video it tomorrow and put it on YouTube in the morning if yall would care to see
Non foulers are only useful when used with downstream sensors. If used with upstream sensors they prevent the sensor from getting a proper exhaust sample and the air fuel mixture will be wrong. Joe's car is a 94 model and does not use downstream sensors to monitor the cats.
#20
Okay so I just made a video. I am using a mobile phone so I can't paste a link here. But if you go to YouTube and look up mustang88 it should come up. Video is called something like 1994 camaro rough idle and in the video I say injectors I mean to say spark plugs
